[mapserver-users] tiff problem,
Jim Burnett
jimburnett at ntelos.net
Mon Jan 28 14:21:37 EST 2002
were is the error?
----- Original Message -----
From: "Pushkar Pradhan" <pushkar at ERC.MsState.Edu>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, January 28, 2002 12:53 PM
Subject: [mapserver-users] tiff problem,
> I am trying to display tiffs using MS 3.5. I get the foll. as part of
> the mesg. when I run my configure script:
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
> using libjpeg from system libs.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... yes
> using libtiff from system libs.
> And if I've understood correctly TIFF support is included when I do a
> normal 'make'.
> The foll. is my layer defn. for tiff:
> LAYER
> NAME mosaic_1999_false
> TYPE RASTER
> STATUS DEFAULT
> DATA data/mosaic_1999_false.tif
> END
> The images are 8-bit so should render correctly, but all I get is a blank
> image. I used examples from the mailing list archive to define the layer.
> If anybody can point out the problem. Thanks,
> PUSHKAR S. PRADHAN
> Research Assistant
> MISSISSIPPI STATE UNIVERSITY,
> STARKVILLE, MS 39759.
> Engineering Research Center
> Box 9627
> Mississippi State, MS 39762-9627
