[mapserver-users] [Fwd: example1]
Steve Lime
steve.lime at dnr.state.mn.us
Thu Jan 31 13:11:38 EST 2002
You're correct sir. Mapfiles *MUST* end in .map. I felt that it was
safer that way (i.e. people can't
request /etc/passwd), same goes for template files.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Tyler Mitchell" <TMitchell at lignum.com> 01/29/02 11:49AM >>>
Does the map file have to have a .map extension maybe? I don't know
but
maybe .map2 is not legal.
Jamie Smedsmo
<jsmedsmo at gis.umn.edu> To:
mapserver-users at lists.gis.umn.edu
Sent by: cc: orkun
<temiz at deprem.gov.tr>
owner-mapserver-users at lists.g Fax to:
is.umn.edu Subject:
01/29/2002 08:10 AM
-------- Original Message --------
Subject: example1
Date: Tue, 29 Jan 2002
16:13:09 +0200
To: projects at lists
Hi
I am newly acquaint with mapserver.
So I am trying to learn the basic things.
The problem I have run into is:
firstly I prepared a html file to fire up as:
<html>
<head><title>Heyelan</title></head>
<body bgcolor="#FFFFFF">
<center><h2>heyelan</h2></center>
<p><hr><p>
<form method=GET action="/cgi-bin/mapserv">
<input type="hidden" name="map" value="/var/www/html/demo.map2">
<input type="hidden" name="layer" value="heyha6">
<input type="hidden" name="program" value="/cgi-bin/mapserv">
<center><input type="submit" value="Initialize"></center>
</form>
</body></html>
Then maplist (as demo.map2)
NAME map
EXTENT 4660000 4520000 480000 640000
SIZE 100 100
SHAPEPATH "/var/www/html"
LAYER
NAME "hey_ha6"
DATA hey_ha6
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 250 175 25
END # end of class object
END # end of layer object
END # end of map file
But every time I get this message : msLoadMap(): Unable to access
file.
Illegal mapfile name.
could you tell me what I didn't fulfill ?
I look at the example1. if I am not wrong, that only contains two files
and
doesn't any template file.
I just want see a single map shape file.
How can I do that with a GRASS map?
Thanks in advance
Ahmet Temiz
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
