[mapserver-users] PostGIS and Temporary Tables
Tyler Mitchell
TMitchell at lignum.com
Fri Jul 26 07:50:56 PDT 2002
Can you access other postgis tables okay?
Homme Zwaagstra
<hrz at geodata.soton.ac.uk> To: mapserver-users at lists.gis.umn.edu (Mapserver
Sent by: Users)
owner-mapserver-users at lists. cc:
gis.umn.edu Fax to:
Subject: [mapserver-users] PostGIS and Temporary Tables
07/26/2002 06:34 AM
Hi List,
I get the following error
Warning: MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error
executing POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it
failed too).
when I try and retrieve data from a temporary PostgreSQL table using
PostGIS (i.e. in the mapfile: DATA "geometry from temp_table").
I'm using MapServer version 3.5 (with INPUT=POSTGIS) with PostGIS 0.7
and PostgreSQL 7.2.1 on i686-pc-linux-gnu, compiled by GCC 2.96.
This is exactly the same error that is returned when I try and
retrieve data from a view. Are the two errors related and how would I
go about solving them? I think a patch I read about would enable me to
implement a workaround
http://postgis.refractions.net/pipermail/postgis-users/2002-May/001014.html
but where can I get it from?
To those in the know, thanks in advance for any help!
Homme Zwaagstra.
More information about the MapServer-users
