[mapserver-users] PHP MapObj serialization?
Vinko Vrsalovic
vinko at cprsig.cl
Tue Jul 30 01:44:46 EDT 2002
Hello,
I'm trying to serialize a PHP MapObj for further use (another
page from the same session).
From what I've read, this will not work if you don't have the
definition of the class in all the pages the object will be
used.
I also presume that dl'ing the .so is not what is meant by
definition of the class. Is serializing and/or saving in a
session variable the mapobj possible?
Ex:
p1.php
<?php
dl('php_mapscript.so');
session_start();
$map = ms_newMapObj("file.map");
$map->draw();
$_SESSION['map'] = $map;
/* or
$_SESSION['map'] = serialize($map);
p2.php
<?php
session_start();
$map = $_SESSION['map'];
/* or
$map = unserialize($_SESSION['map']);
As I understood from the docs the serialization is not needed when
using $_SESSION.
If i serialize/unserialize, i get the long forgotten:
Fatal error: Object has an invalid _handle_ property in ...
If i don't serialize/unserialize, i get the same error. :)
Is there a trick to make PHP see the MapObj definition?
Thanks,
Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
http://www.cprsig.cl
