[mapserver-users] Easy Mapserver demo (was:  New User)
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Sun Jun  2 14:57:26 PDT 2002
Nicolas,
This sounds great! Give it a try and let us know how it works. I would
suspect that you might have problems with needing a writable directory
pn the hard disk for mapserver to dump images, etc. into, so you might
need to some how configure a hard disk directory to be mapped into the
web servers htdocs tree.
-Steve
Nicolas Boretos wrote:
> Hi,
> I've got a simple webserver and mapserver all packaged up that basically
> you click and run. I have not tried to run off a cd, but can give it a
> shot if youd like. Let me know if you have any interest...
> sincerely,
> nicolas boretos
> Tyler Mitchell wrote:
> > A while back I had demoed a program that was a mini web server that could
> > run straight off a cdrom.  It included CGI support.  Does this ring a bell
> > with you?  I'm trying to find this program again - any suggestions?
> > I'd like to work with others to get Mapserver and related technologies
> > working in such an environment for demostration purposes.  Have you done
> > any work on this sort of thing?
> > Drop me if this sounds good to you or if you have any pointers for me.
> > Tyler
> >                       "Simon Kirkness"
> >                       <Simon.Kirkness at fisheries.ns        To:       <mapserver-users at lists.gis.umn.edu>
> >                       w.gov.au>                           cc:
> >                       Sent by:                            Fax to:
> >                       owner-mapserver-users at lists.        Subject:  [mapserver-users] New User
> >                       gis.umn.edu
> >                       05/29/2002 05:41 PM
> > Hi All,
> > Am I able to run the MapServer application and Demo on a PC independant
> > of a web server?
> > Simon Kirkness
> > NSW Fisheries
> > Project Officer
> > Threatened Species
> > Port Stephens Fisheries Centre
> > Ph: (02) 4916 3810
> > Fax: (02) 4916 3880
> > Email: kirkness at fisheries.nsw.gov.au
> > Note: This message is intended for the addressee named and may contain
> > confidential information. If you are not the intended recipient,
> > please
> > delete it and notify the sender.  Views expressed in this message are
> > those
> > of the individual sender, and are not necessarily the views of NSW
> > Fisheries.
> > (See attached file: InterScan_Disclaimer.txt)
More information about the MapServer-users
