[mapserver-users] regex question
Puneet Kishor
pkishor at GeoAnalytics.com
Mon Jun 3 08:41:51 EDT 2002
try
expression "/^%KT2 %U65/"
if '%KT2 %U65' is the exact and only match, you could also add a $ at
the end like so...
/^%KT2 %U65$/
keep in mind, the single space in between will get matched...
On Monday, June 3, 2002, at 05:01 AM, Anders Knudstrup Hansen LE34
wrote:
> Hello....
> I'm trying to use regex in my class expressions... The item that I'm
> trying to match consists of 2 parts.
> example:
> expression /^"%KT2 %U65"/ doesn't work
> expression "%KT2 %U65" works fine
> What is the problem with my regular expression?????
> Thanks
> / Anders
