[mapserver-users] rectangle in reference map
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Tue Jun 4 11:52:39 EDT 2002
# Start of reference map
REFERENCE
IMAGE graphics/reference.png
EXTENT 482572 1031082 639981 1151888
SIZE 300 232
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
Should be sufficient, works fine with standalone CGI as well as mapscript.
Hope this helps.
> Probably it is something quite stupid.
> I hesitated to question it here, but it seems my only hope left...
> I'd like to have a nice red rectangle in my reference map, showing me where I
> am in the map.
> I've set up a reference map in the map file, which displays OK. Only no red
> (neither other color) rectangle appears. Do I need to do something more than
> just refimage=$map->drawReferenceMap(); ?
> A rectangle query or something? The mapfile definition page mentions something
> like that at the reference object, but I can't find anything similar in the
> php_mapscript object definitions like a queryRectangle method or something
> similar...
> All images that I use are png.
> PHP=4.1.2
> Mapserver/mapscript = 3.6.0
> I already tried playing around with the color and outlinecolor items, but
> nothing happened.
> Thanks,
> Vincent.
> Here comes my map file:
> NAME "samboja"
> SIZE 400 440
> STATUS ON
> EXTENT 492499.336 9879200.289 502498.366 9890199.289
> UNITS METERS
> TRANSPARENT ON
> PROJECTION
> "proj=utm"
> "ellps=GRS80"
> "zone=50"
> "south"
> "no_defs"
> END
> SHAPEPATH "./data"
> WEB
> IMAGEPATH "/home/samboja/ms_tmp/"
> IMAGEURL "/samboja/ms_tmp/"
> MAXSCALE 70860
> MINSCALE 4428
> END
> REFERENCE
> IMAGE "/home/samboja/ms_data/data/reference/sl_ref.png"
> COLOR 255 0 0
> SIZE 100 110
> STATUS ON
> END
> LAYER
> NAME "IKONOS2001"
> MAXSCALE 70860
> MINSCALE 70859
> DATA "tilez0/1x1.png"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME "IKONOS2001"
> MAXSCALE 70859
> MINSCALE 35429
> TILEINDEX "tilez1_idx.shp"
> TILEITEM "Location"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME "IKONOS2001"
> MAXSCALE 35429
> MINSCALE 17714
> TILEINDEX "tilez2_idx.shp"
> TILEITEM "Location"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME "IKONOS2001"
> MAXSCALE 17714
> MINSCALE 8857
> TILEINDEX "tilez3_idx.shp"
> TILEITEM "Location"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME "IKONOS2001"
> MAXSCALE 8857
> MINSCALE 4428
> TILEINDEX "tilez4_idx.shp"
> TILEITEM "Location"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME "IKONOS2001"
> MAXSCALE 4428
> MINSCALE 0
> TILEINDEX "tilez5_idx.shp"
> TILEITEM "Location"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME "TILETEST"
> DATA "tilez1_idx.shp"
> TYPE POLYGON
> CLASS
> COLOR -1 -1 -1
> OUTLINECOLOR 0 200 0
> END
> STATUS ON
> END
> END
-Pushkar S. Pradhan
