[mapserver-users] Re: [postgis-users] sql works, but not as layer?
    Dave Blasby
    dblasby at refractions.net
    Tue Jun  4 09:43:51 PDT 2002
> CONNECTION "user=postgres dbname=food host=10.0.0.2"
> DATA "the_geom from objecteigenschappen o left join pc6punten p on
> p.pc6=o.eigenschap_3"
> FILTER "(the_geom && GeometryFromText('BOX3D(109258 559953,115258
> 565953)'::box3d,-1) and distance(the_geom, GeometryFromText('POINT(112258
> 562953)',-1)) < 3000)"
You're using the DATA parameter incorrectly - its a bit confusing.
The generic templates are:
DATA "<geom column name> from <table name>"
	or
DATA "<geom column name> from (<sql statement>) as foo"
In your case, use:
DATA "the_geom from (SELECT * from objecteigenschappen o left join
pc6punten p on p.pc6=o.eigenschap_3) as foo"
hope that works,
dave
More information about the MapServer-users
