[mapserver-users] Web Server Tricks... Kind of Off Topic
Steven Bowden
steveb at bundaberg.qld.gov.au
Tue Jun 4 19:41:36 EDT 2002
I think it is called port forwarding. Not sure how you set it up in
windows land and have only just started to have a look at it on linux.
Basically I think the theory is that you map any requests received on a
port (ie port 80 for apache) and tell it to forward it to another IP
address.
In Linux land it canbe done using ipchains or iptables I think. Also
have a look at NAT (Network Address Translation).
Another option could be to use a database that holds your data on the
faster machine eg postgres with postgis and have your .map file on the
slower webserver connect to the faster machine to access the data. That
way you don't need to set up any port forwarding stuff. This way might
not be as quick as the port forwarding way but it might be quicker than
doing it all on the slow machine.
Steve Bowden
GIS Officer
Bundaberg City Council
On Wed, 2002-06-05 at 07:43, Hankley, Chip wrote:
I am by no means a guru at configuring / working out web server hardware /
networking issues... and could use a little guidance.
Our main webserver is pretty much a dog. We're running a 200 MHz dual
processor server w/ win2K and IIS... it handles a number of things for our
company (besides mapserver)... and it is S L O W (i know... 200 MHz,
Win2K... big part of the problem).
Anyway... my options are limited b/c of internal politics and the like - so
Linux is out, as well as my own dedicated server.
What I'm wondering is if there is some way to "pass-through" my mapserver
requests to a more powerful box within the organization. For instance, a MS
request would come in, and instead of being processed on that server, the
actual mapserver work (the process of rendering the image from the raw GIS
data) would occur on another more powerful machine, and then the image
either would be passed back for service to the client, or would be read
directly from that machine. Is such a thing possible? What would be the
performance implications of such a trick?
I think this is kind of how MO IMS and ArcIMS work in that there is a "Map
Server" that runs as a service... not necessarily on the web server.
TIA
Chip Hankley
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020605/a068294a/attachment.html
