[mapserver-users] Font as a symbol?
Daniel Morissette
morissette at dmsolutions.ca
Wed Jun 5 17:14:21 EDT 2002
For the record, this has been fixed only in the 3.7-dev source (CVS)...
so until the 3.7 release is available, then the workaround is to keep
TRUETYPE symbols in a symbolset file as you mentioned.
Daniel
Richard Greenwood wrote:
> I ran into this also. Putting the truetype symbol definition into the
> SYMBOLSET file, rather than defining it in the .map file fixed it for me.
> Rich
> At 02:05 PM 6/5/2002 -0400, you wrote:
> >We are having no luck trying to use a font for a symbol. The following is
> >the relevant code. Any suggestions would be helpful. We do not get any
> >errors, the symbols just don't show.
> ><symbol definition in mapfile>
> >SYMBOL
> > NAME "arial"
> > TYPE TRUETYPE
> > FONT arial
> > FILLED false
> > ANTIALIAS true
> > CHARACTER "a"
> >END
> ><layer definition in mapfile>
> >LAYER
> > NAME stories
> > METADATA
> > "DESCRIPTION" "Local Stories"
> > "RESULT_FIELDS" "STORY_ID"
> > END
> > TYPE POINT
> > STATUS DEFAULT
> > TOLERANCE 10
> > TOLERANCEUNITS pixels
> > CLASS
> > NAME "Icon_id"
> > TEMPLATE void
> > SYMBOL 'arial'
> > SIZE 10
> > COLOR 0 0 0
> > END
> >END
> ><fonset definition in mapfile>
> >FONTSET "c:/inetpub/wwwroot/digilib/mapserver/fonts/fonts.txt"
> ><font mapping in font.txt>
> >arial
> >c:/zinetpub/wwwroot/digilib/mapserver/fonts/ARIAL.TTF
> >Regards,
> >Joost van Ulden
> >Data Integration Specialist
> >GSC-Pacific Division
> >101-605 Robson St.
> >Vancouver, BC V6B 5J3
> >604.666.7525
> >jvanulde at nrcan.gc.ca
> Richard W. Greenwood, PLS
> Greenwood Mapping, Inc.
> Rich at GreenwoodMap.com
> (307) 733-0203
> http://www.GreenwoodMap.com
