[mapserver-users] php/mapscript versions 3.5+ Fatal error: Object has an invalid _handle_ property
Ellis Robin (Bundaberg)
Robin.Ellis at nrm.qld.gov.au
Thu Jun 6 03:11:45 EDT 2002
Hi List,
I have managed to compile ms3.5 with mapscript using php4.0.6
(via CGI) on Solaris Unix running Apache1.3.24. I am able to display
data sets straight out of the mapfile OK, but when I try to give the
user some control over the visibility of layers I get this error message
(which seems to have been around a bit in the past):
The mapscript I am attempting to implement looks like this:
$mapimg = $map->prepareImage();
$layer = $map->getLayerByName("citrus");
$layer->set('status', 'ON');
$layer->draw($map,$mapimg);
With the error message indicating that it is the
$layer->draw($map,$mapimg); line causing the problem.
After going through the mail archive I found that there was a known bug
with php4.0.6, so I have just gone through the process of compiling and
installing php4.2.0 and mapserver3.6, however I still get the same
message. As I say, I've been through the mail archive extensively and
haven't found a work around yet that solves the problem.
Does anyone have suggestions as to how I may overcome this problem?
Thanks very much
Rob
Robin Ellis
Department of Natural Resources and Mines
PO Box 1167
Bundaberg QLD 4670
+61 7 4131 5771
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
