[mapserver-users] bug: postgis connector subselects
Twan Kogels
twan at twansoft.com
Thu Jun 6 08:39:17 EDT 2002
Hello,
I think i've found a bug in the postgis connector. When you do a subselect
in the DATA field and the first table is not the table with a geometric
column, the resultset will be empty.
pc6punten is the table with the geometric column.
objecteigenschappen is a normal table, without geometric information.
A example:
DATA "the_geom from (select p.oid, p.* from pc6punten p,
objecteigenschappen o where o.eigenschap_3=p.pc6) as foo"
Works oke, because in pc6punten a geometric column named the_geom exists.
DATA "the_geom from (select p.oid, p.* from objecteigenschappen o,
pc6punten p where o.eigenschap_3=p.pc6) as foo"
Returns a empty resultset aka no points.
Anothe example:
DATA "the_geom from (select p.oid, p.* from pc6punten p left join
objecteigenschappen o on p.pc6=o.eigenschap_3 where o.keur<>'') as foo"
Works oke.
DATA "the_geom from (select p.oid, p.* from objecteigenschappen o left join
pc6punten p on p.pc6=o.eigenschap_3 where o.keur<>'') as foo"
Returns a empty resultset.
When using a normal postgresql client, all queries returns points.
I'm using mapserver 3.6.
Best regards,
Twan
http://www.twansoft.com
