[mapserver-users] hue, saturation, value -> RGB
Michael Schulz
mschulz at webgis.de
Thu Jun 6 09:40:32 EDT 2002
below is a snipplet avenue-code, that we use to get the RGB-Values of classified
legends. Perhaps your client can use it to give you the RGB-Values: Basically,
you use it on a LegendObj to get the Symbols, then get the colors as a list of
rgb int values and e.g. write it to a textfile.
--- snip
theClassesList = theLegend.GetClassifications
symbols = theLegend.GetSymbols
n = theClassesList.Count-1
d = Dictionary.Make(0)
for each e in 0..n
aClass = theClassesList.Get(e)
aSymbol = symbols.get(e)
aColor = aSymbol.getColor.getRGBList
R = aColor.get(0).asString
G = aColor.get(1).asString
B = aColor.get(2).asString
aString = R+" "+G+" "+B
aTextfile.WriteElt(aString)
d.add (akey.Asstring, {aLabel,symbols.get(e)})
end
---snip
HTH, Cheers, Michael
"Hankley, Chip" schrieb:
> Unfortunately they are built in functions that do the RGB<->HSV conversions.
> I've never tried this, but you might be able to manually convert the values
> from the ArcView flavor of HSV to the Photoshop flavor of HSV.
> So, for instance, in PS (and strangely ArcInfo...why they didn't use the
> same color model is beyond me) H is 0-360, and S and V are both 0 to 100.
> So, say you have an AV HSV color specified as 255 255 255
> This should be equivalent to a PS value of
> H: 360 (or 0)
> S: 100
> V: 100
> Your formula for the conversion should be:
> H_PS = (H_AV / 255) * 360
> S_PS = (S_AV / 255) * 100
> V_PS = (V_AV / 255) * 100
> where H_PS is the HUE value in Photoshop, and H_AV is the HUE value in
> ArcView, and so on.
> If you've got a long list, you could do all the conversions in a
> spreadsheet, then move over to PS.
> Hope that helps!
> Chip
> -----Original Message-----
> From: Pushkar Pradhan [mailto:pushkar at ERC.MsState.Edu]
> Sent: Wednesday, June 05, 2002 12:40 PM
> To: Hankley, Chip
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [mapserver-users] hue, saturation, value -> RGB
> Thanks to everybody,
> I did it in photoshop, that exe program, but as Chip has said the Arcview
> values of H,S and V are different, thus most programs won't let me use a
> Saturation value of 255 etc.
> Are these avenue scripts inbuilt in arcview, can anybody point out how to
> use them to do conversion.
> > As Stephen pointed out, there are some good formulas via the Google search
> > page that you can wade through to figure it out...
> > However, some words of caution.
> > The way ArcView calculates HSV is a little different. Values for H, S, and
> V
> > all range from 0 to 255 (I believe). This is different from other HSV
> color
> > models. If you have access to ArcView, there are some simple avenue
> scripts
> > that will do the conversion for you (or you might be able to get your
> client
> > to do it).
> > Chip
> > From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> > Sent: Wednesday, June 05, 2002 4:57 AM
> > To: Pushkar Pradhan
> > Subject: Re: [mapserver-users] hue, saturation, value -> RGB
> > http://www.google.com/search?hl=en&q=hsv+to+rgb&btnG=Google+Search
> > Pushkar Pradhan wrote:
> > > Hi,
> > > I have a client who has given me the color hue, saturation and value
> > > attributes for each shapefile. He got these values from arcview's legend
> > > table. Doesn anyone know how to translate these values to pure R, G and
> B
> > > so that mapserver can understand it?
> > > Thanks,
> > > -Pushkar S. Pradhan
> -Pushkar S. Pradhan
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
