[mapserver-users] WMS Client
Paul Ramsey
pramsey at refractions.net
Thu Jun 6 16:18:10 EDT 2002
In answer to my own question: it appears that the WMS Client does not
like image/jpeg as a format at all. When using image/png, things work,
although the mapping from 24-8bit color is atrocious. Using image/gif
gives a perfectly reasonable result. I assume if the png was 8 bit the
results would be equally satisfactory.
Paul Ramsey wrote:
> Any idea why the following request is not working? I can see the request
> being made in the logs of the WMS server referenced here, and if I type
> that request into a browser window, I can actually see the WMS image is
> getting correctly generated, but the final output from mapserver never
> contains the WMS client data.
> # DYNAMIC HILLSHADING
> LAYER
> NAME "hillshd"
> TYPE RASTER
> CONNECTIONTYPE WMS
> CONNECTION
> "http://tserver/pramsey/tserver/php/hillshd/hillshd.php?serviceId=6&VERSION=1.1.0&LAYERS=hshd315&FORMAT=image/jpg"
> PROJECTION
> "init=epsg:26909"
> END
> METADATA
> "wms_title" "Hillshading"
> "wms_opaque" "1"
> "wms_srs" "EPSG:26909 EPSG:26910"
> END
> END
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
__
| Paul Ramsey
\_
