[mapserver-users] oracle spatial layer not shown
Gregor Friedrich gregor at hdg.ufz.de
Fri Jun 7 02:24:44 PDT 2002
Hi Folks
I have trouble to set up a mapservice with a oracle spatial layer. The
setup in the mapfile (EXTENT, LAYER, TEMPLATE) is the same like the
shapefile version and the shapefile has been uploaded with the oracle
shapefile uploader for Oracle 9i. (shp2sdo) The are no error messages from
mapserv(ORA... etc), but the map is still emty (blank). The shapefile
version works fine and the logfiles are exactly the same ....
The mapserver (3.6)  works on a PII Linux system (SUSE 7.3) with Oracle 9i
Client
oracle -log
Fri Jun  7 10:33:11 2002,7770,141.65.97.151,Biotoptypen,0,4582813.250000
5616806.700000 4602365.750000 5632464.300000,-1.000000 -1.000000,biotges
,normal execution
file-log
Fri Jun  7 10:32:39 2002,7769,141.65.97.151,DEMO,0,4582813.250000
5616806.700000 4602365.750000 5632464.300000,-1.000000 -1.000000, biotges
,normal execution
Here are the map definitions:
file - version:
# Start of map file
NAME DEMO
STATUS ON
SIZE 550 440
EXTENT 4582813.250 5619330.750 4602365.750 5629940.250
UNITS METERS
FONTSET /usr/local/httpd/htdocs/fonts/fonts.list
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
# Start of web interface definition (including WMS enabling metadata)
WEB
   #HEADER demo_header.html
   TEMPLATE biotop.html
   #FOOTER demo_footer.html
   MINSCALE 1000
   MAXSCALE 1550000
   LOG "/usr/local/httpd/htdocs/tmp/test4.log"
   IMAGEPATH "/usr/local/httpd/htdocs/tmp/"
   IMAGEURL "/tmp/"
   METADATA
     WMS_TITLE "UFZ MapServer "
     WMS_ABSTRACT "Biotoptypen und Brunnen Beispiel 1"
     WMS_ACCESSCONSTRAINTS none
     # change this value to match your setup
     WMS_ONLINERESOURCE "http://host/test4/index.html"
     WMS_SRS "EPSG:4326"
   END
END
QUERYMAP
   SIZE 200 200
   STATUS ON
   STYLE HILITE
   COLOR 255 0 0
END
# Start of reference map
REFERENCE
   SIZE 150 160
   IMAGE graphics/ref_map.png
   EXTENT 4583702.000 5619813.000 4601477.000 5629458.000
   STATUS ON
   COLOR -1 -1 -1
   OUTLINECOLOR 255 0 0
END
LEGEND
STATUS ON
   LABEL
     TYPE TRUETYPE
     FONT arial
     SIZE 10
     COLOR 0 0 0
#    ANTIALIAS
   END  #Label
END   #LEGEND
# Start of scalebar
SCALEBAR
   LABEL
     COLOR 0 0 0
     SIZE SMALL
   END  #LABEL
   SIZE 300 5
   COLOR 255 255 255
   BACKGROUNDCOLOR 0 0 0
   OUTLINECOLOR 0 0 0
   UNITS meters
   INTERVALS 10
   STATUS ON
END   #SCALEBAR
# Start of layer definitions
LAYER
   NAME biotges
   TYPE Polygon
   STATUS on
   DATA biotges
   CLASS
      COLOR 128 128 128
      OUTLINECOLOR 0 0 0
   END  # CLASS
END  # LAYER
END  # MAPFILE
oracle spatial version:
# Start of map file
NAME Biotoptypen
STATUS ON
SIZE 550 440
UNITS METERS
WEB
   TEMPLATE index.html
   LOG "/usr/local/httpd/htdocs/tmp/bio_spatial.log"
   IMAGEURL "/tmp/"
   METADATA
     WMS_ONLINERESOURCE "http://host/bio_spatial/init.html"
     WMS_SRS "EPSG:4326"
   END
END
REFERENCE
   SIZE 150 160
   STATUS ON
   COLOR -1 -1 -1
END
# Start of scalebar
SCALEBAR
   LABEL
     COLOR 0 0 0
     SIZE SMALL
   END  #LABEL
   SIZE 300 5
   COLOR 255 255 255
   OUTLINECOLOR 0 0 0
   UNITS meters
   INTERVALS 10
   STATUS ON
END   #SCALEBAR
LAYER
   NAME biotges
   CONNECTIONTYPE oraclespatial
   CONNECTION "user/passwd at sid"
   TYPE Polygon
   STATUS on
   DATA "geom FROM BIOTGES"
   CLASS
     COLOR 128 128 128
     OUTLINECOLOR 0 0 0
   END  # CLASS
END  # LAYER
END  # MAPFILE
Any ideas ???
Thanks in advance
  Gregor
More information about the MapServer-users mailing list
