[mapserver-users] Rosa and javascript
Hankley, Chip
Chip.Hankley at GASAI.Com
Thu Jun 13 10:40:15 EDT 2002
Guillaume -
There should be some documentation on the ROSA applet that came with the
distribution, otherwise go to:
http://www2.dmsolutions.ca/webtools/rosa/rosa_params.html
The applet is not "doing" anything per se, except providing a convenient way
to pass information to the form. For instance, the applet does not handle
the zoom functionality for a MapServer or MapScript application... you have
to do that elsewhere. I've put an explanation on what each of these does
below.
<PARAM NAME="TB_BUT_print_IMG" VALUE="../MapSymbols/PrintOff.gif">
- specifies the OFF image
<PARAM NAME="TB_BUT_print_IMG_PR" VALUE="../MapSymbols/PrintOff.gif">
- specifies the image to show when PRESSED
<PARAM NAME="TB_BUT_print_HINT" VALUE="Print this Image">
- optional, displays a hint on mouseover
<PARAM NAME="TB_BUT_print_INPUT" VALUE="submit">
- what to do when the user clicks on the button
<PARAM NAME="TB_BUT_print_NAME" VALUE="CMD">
- the form variable associated with this button
<PARAM NAME="TB_BUT_print_VALUE" VALUE="PRINT">
- the value to apply to the form variable
<PARAM NAME="TB_BUT_print_JSACTION" VALUE="fnxPrint()">
- optional, the JS function to call when clicked
Note that your not seeing the full applet here... you might want to go to
the URL that I sent you before, and "view source" to see the whole thing. Or
go the the GMAP demo and do it there. Then you can see all of the pieces.
Chip
-----Original Message-----
From: Guillaume Sueur [mailto:guillaume.sueur at khi2.fr]
Sent: Thursday, June 13, 2002 9:13 AM
To: Hankley, Chip
Subject: Re: [mapserver-users] Rosa and javascript
Thanks to everybody for those precisions. Do the value and name parameters
useful here, or are they only used to disconnect other functions like zoom
in ?
Guillaume
