[mapserver-users] Thematic points by database values
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 14 08:32:07 PDT 2002
You might try something like LABELSIZEITEM and then use a truetype font
to draw the symbol. If you need to label the item also, the dupicate the
LAYER and make it TYPE ANNOTATION to draw the label.
-Steve
"Martin, Daniel" wrote:
> I am trying to add thematic points by a value in the database. Every
> example I've seen involves the use of many classes. I'd rather avoid that,
> because my point values have an undetermined range, and change often.
> I'm looking for something along the lines of:
> CLASS
> SIZE 4 + MyDbaseItem
> END
> But, I haven't found anything that works. Is it possible to do this?
> Thanks,
> Dan Martin
More information about the MapServer-users
