[mapserver-users] Thematic points by database values
Martin, Daniel
DMartin at erac.com
Fri Jun 14 13:39:17 EDT 2002
Lowell mentions Mapscript, and I thank him for the reply. Unfortunately,
I'm in the pure CGI world.
Steve, thanks for your suggestion. I tried it, but for some reason my
points don't seem to be resizing based on the LABALSIZEITEM. Or if they do,
it's so small it's unnoticeable.
Here's my Layer:
LAYER
NAME "Outsources YTD 2002"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "\GISData\Outsources.TAB"
STATUS OFF
LABELSIZEITEM "Total"
CLASS
NAME 'Outsources YTD 2002 Through April 30'
COLOR -1 -1 -1
TEXT "."
LABEL
POSITION cc
TYPE TRUETYPE
FONT arial
FORCE true
COLOR 255 0 0
OUTLINECOLOR 0 0 0
ANTIALIAS true
MINSIZE 25
MAXSIZE 300
END
END
END
Any Ideas why it always seems to be the MINSIZE, no matter what the value of
the LABELSIZEITEM? I should mention the values are going to be around the
range of 1-15.
Thanks,
Dan Martin
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Friday, June 14, 2002 10:32 AM
To: Martin, Daniel
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Thematic points by database values
You might try something like LABELSIZEITEM and then use a truetype font
to draw the symbol. If you need to label the item also, the dupicate the
LAYER and make it TYPE ANNOTATION to draw the label.
-Steve
"Martin, Daniel" wrote:
> I am trying to add thematic points by a value in the database. Every
> example I've seen involves the use of many classes. I'd rather avoid
that,
> because my point values have an undetermined range, and change often.
> I'm looking for something along the lines of:
> CLASS
> SIZE 4 + MyDbaseItem
> END
> But, I haven't found anything that works. Is it possible to do this?
> Thanks,
> Dan Martin
