[mapserver-users] Thematic points by database values
Martin, Daniel
DMartin at erac.com
Fri Jun 14 15:18:35 EDT 2002
Is there any way to use an expression with LABELSIZEITEM? I tried, but
Mapserver choked on it.
Thanks,
Dan
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Friday, June 14, 2002 2:11 PM
To: Martin, Daniel
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Thematic points by database values
Martin, the value of "Total" if used for LABELSIZEITEM must be in pixels
for font height.
-Steve
"Martin, Daniel" wrote:
> Lowell mentions Mapscript, and I thank him for the reply. Unfortunately,
> I'm in the pure CGI world.
> Steve, thanks for your suggestion. I tried it, but for some reason my
> points don't seem to be resizing based on the LABALSIZEITEM. Or if they
do,
> it's so small it's unnoticeable.
> Here's my Layer:
> LAYER
> NAME "Outsources YTD 2002"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "\GISData\Outsources.TAB"
> STATUS OFF
> LABELSIZEITEM "Total"
> CLASS
> NAME 'Outsources YTD 2002 Through April 30'
> COLOR -1 -1 -1
> TEXT "."
> LABEL
> POSITION cc
> TYPE TRUETYPE
> FONT arial
> FORCE true
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> ANTIALIAS true
> MINSIZE 25
> MAXSIZE 300
> END
> END
> END
> Any Ideas why it always seems to be the MINSIZE, no matter what the value
of
> the LABELSIZEITEM? I should mention the values are going to be around the
> range of 1-15.
> Thanks,
> Dan Martin
> Sent: Friday, June 14, 2002 10:32 AM
> To: Martin, Daniel
> You might try something like LABELSIZEITEM and then use a truetype font
> to draw the symbol. If you need to label the item also, the dupicate the
> LAYER and make it TYPE ANNOTATION to draw the label.
> -Steve
> > I am trying to add thematic points by a value in the database. Every
> > example I've seen involves the use of many classes. I'd rather avoid
> that,
> > because my point values have an undetermined range, and change often.
> > I'm looking for something along the lines of:
> > CLASS
> > SIZE 4 + MyDbaseItem
> > END
> > But, I haven't found anything that works. Is it possible to do this?
> > Thanks,
> > Dan Martin
