[mapserver-users] WMS and MapScript 3.6 beta 2
Daniel Morissette
morissette at dmsolutions.ca
Mon Jun 17 08:45:51 EDT 2002
Is it possible that you did 'make install' in the mapserver directory
with a previous configuration (without wms-client)?
Due to the way the build process is setup, the 'make install' target
should never be used... it gives no benefit except build problems with
the various versions of MapScript. Try deleting /usr/local/lib/libmap.a
and /usr/local/include/map.h, and then recompile your mapserver.
Daniel
Agnieszka ¯ak wrote:
> Hi,
> I have strange problem. I have complied MapServer 3.6 beta 2 with options:
> "./configure" \
> "--with-proj" \
> "--with-php=../php-4.2.1" \
> "--with-gdal=/home/src/gdal-1.1.7" \
> "--with-ogr" \
> "--enable-runpath" \
> "--without-tiff" \
> "--with-gd" \
> "--with-libwww=/home/src/libwww" \
> "--with-wms" \
> "--with-wmsclient" \.
> When I type mapserv -v I get:
> MapServer version 3.6.0-beta2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> but in phpinfo() I have:
> MapScript Version ($Revision: 1.104 $ $Date: 2002/04/24 20:37:32 $)
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG
> So I can't use WMS_CLIENT in PHP.
> Thanks for any help.
> Regards,
> Agnieszka ¯ak
> INTERIA.PL: Portal pelen informacji... >>> http://link.interia.pl/f15ed
