[mapserver-users] Support for PNG Symbols
randy james
rjames57 at yahoo.com
Mon Jun 17 17:37:20 EDT 2002
Hi
I had a error like the one you have, and it was
because i did not define the symbol in my symbol.sym
file. It looks like you are trying to load a symbol as
a image from your map file, when you should be
defining and naming your symbol in the symbol.sym file
and than load the defined symbol in your map file.
Make any sense?
your symbol.sym file should contain something like
Symbol
Name 'ctyhwy'
Type PIXMAP
Image 'images/ctyhwy.gif'
Transparent 7
END
Hope i did not confuse the issue
--- Referencia SA <georef at tie.cl> wrote:
> Thanks Scott for kind reply, i am submitting the
> question again to the list
> to see if some one else have a clue....
> Hi every one
> Finally we have mapserver running. We didn't install
> installed.
> We are playing with itasca demo, and have changed
> all .gif to .png how
> ever we get the following error:
> msLoadMap(): General error message. Undefined
> symbol "symbols/ctyhwy.png"
> in class 0 of layer ctyrdln3_anno.
> Can the symbols be .png or they must be .gif? If
> above possible, how to
> avoid error?
> Off course, if class for symbol is commented (#) the
> demo runs ...
> Juanse
> temuko-chile
> > Juanse,
> > I am not sure about these issues myself since we
> are just starting with
> > the package also. We are using jpegs.
> > Good luck with this topic.
> > Sorry I cannot be of more help.
> > Scott
> > Referencia SA wrote:
> > > Scott
> > > Thanks, i have the example running "commenting
> out" the need section,
> how
> > > ever i would love to have the .png working,
> instead of the .gif images.
> > > I understand that .png is the favoured format
> within linux.
> > > So the question is still valid : can one use
> .png for symbol definition?
> > > Juanse
> > > ----- Original Message -----
> > > From: Scott Davidson <davidson at usgs.gov>
> > > To: Referencia SA <georef at tnet.cl>
> > > Sent: Monday, June 17, 2002 10:21 AM
> > > Subject: Re: [mapserver-users] mapserver 3.6
> compile error
> > > > I believe that you have to comment out the
> sections that use the
> > > > .gif files, not just change the files
> extensions. Comment out the
> > > > porrtion :
> > > > LAYER
> > > > NAME ctyrdln3_anno
> > > > GROUP roads
> > > > MAXSCALE 300000
> > > > STATUS OFF
> > > > DATA ctyrdln3
> > > > TYPE ANNOTATION
> > > > LABELITEM "road_name"
> > > > # CLASS
> > > > # COLOR 255 255 255
> > > > # SYMBOL 'symbols/ctyhwy.gif'
> > > > # LABEL
> > > > # MINFEATURESIZE 40
> > > > # MINDISTANCE 150
> > > > # POSITION CC
> > > > # SIZE TINY
> > > > # COLOR 0 0 0
> > > > END
> > > > END
> > > > And
> > > > # Start of reference map
> > > > #REFERENCE
> > > > # IMAGE graphics/reference.gif
> > > > # EXTENT 393234.393701263 5205405.16440722
> 495769.579718949
> > > 5307959.02579127
> > > > # SIZE 120 120
> > > > # STATUS ON
> > > > # COLOR -1 -1 -1
> > > > # OUTLINECOLOR 255 0 0
> > > > #END
> > > > Then it should work.
> install gif support,
> only
> > > .png
> > > > > installed.
> > > > > how ever we get the following error:
> Undefined symbol
> > > "symbols/ctyhwy.png" in
> .gif?
> > > > > If above possible, how to avoid error?
> > > > > Juanse
> > > > > temuko-chile
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
