[mapserver-users] Mapserver 3.6 - is JOIN supported?
Tom Cadman
Tom.Cadman at region.durham.on.ca
Fri Jun 21 14:53:10 EDT 2002
Does Mapserver 3.6 support the JOIN function for linking a shape file dbf to another dbf file. I believe it was taken out in version 3.5 but was to be put back in in version 3.6. I've got version 3.6 working fine , except fot JOINs - removed QUERY and placed TEMPLATE inside CLASS but it still won't work. Below is an excerpt of may map file dealing with the JOIN
LAYER # subdivision plans
NAME "subdivisions"
TYPE POLYGON
DATA subdivision_condo_plans_region
STATUS OFF
CLASSITEM subdivisio # SUBDIVISIO field
CLASS
SYMBOL 9
SIZE 1
OUTLINECOLOR 0 191 57 # 255 50 255 # medium blue 240 0 245
COLOR 76 255 150 # light green
TEMPLATE "subd_query.html" # for display in new window
JOIN
TYPE multiple
TEMPLATE "subd_query_result.html"
NAME subdjoin
TABLE subcondo.dbf # filename of.dbf to be joined with shapefile .dbf
FROM subdivisio # field in shapefile .dbf file
TO tfile # field to join on in lookup .dbf file
END
END # class
END # layer
