[mapserver-users] installing problem
Hao Ding
hdi12 at it.canterbury.ac.nz
Sun Jun 23 23:14:46 EDT 2002
I downloaded mapserver 3.6.0 and configured it to support OGC WMS server using
mapserver$ ./configure --with-proj=$HOME/local
The proj.4 was installed in the $HOME/local. After compiling with 'make'
mapserver$ make
I got the 'mapserv' and tested it,
mapserver$ ./mapserv
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
So far, everything was well, but when I installed 'mpserv' to
$HOME/apache2/cgi-bin/ and accessed the URL "localhost/cgi-bin/mapserv", I got
Server Error 500.
If I only configured the mapserver source code and compiled it using:
mapserver$ make
and retested, the output was "No query information to decode. QUERY_STRING is
set, but empty.", it was going well.
Can anyone explain what is the problem and how to solve it?
Thanks a lot!
Hao
