[mapserver-users] Mapscript/Java/Servlet users: give this a
whirl...
Harald Wehr
hwehr at hs-harz.de
Thu Jun 27 01:58:43 EDT 2002
Hi CF,
I faced the same problems some times ago and never found a solution to
this problem.
See these mails i wrote to this list.
http://mapserver.gis.umn.edu/wilma/mapserver-users/0203/msg00298.html
http://mapserver.gis.umn.edu/wilma/mapserver-users/0204/msg00137.html
http://mapserver.gis.umn.edu/wilma/mapserver-users/0203/msg00373.html
> I've been having this very unusual problem running servlets and
> mapscript. As far as I can tell, it's working great except under one
> condition. If a user submits a request to the servlet, then hits the
> browser's refresh button before the his/her previous one is finished, it
> *crashes* my servlet engine. This only happens if I'm executing
> imageObj.draw() somewhere in it *and* trying to print a response back to
> the client. If I don't do anything with my HTTPServletResponse object,
> I can hit refresh as many times as I want as fast as I want with no
> problems. Anyway, without getting too deep into the issue, etc. I would
> be grateful if someone else could try doing this.
It is really curios to find the responsible fault. Sometimes it worked
several times, some times the sevlet container crashes.
> Submit a request to your servlet that draws a map and saves out to an
> image (one that takes at few seconds or more).
> Then hold your <CTRL> key down (to make sure it refreshes) and hit your
> refresh button a few times fast while your first request is still pending.
> Sometimes it'll keep showing you the cached page after the servlet
> engine has crashed. So after that, try moving to another page being
> served by your servlet engine, or change your url params or just somehow
> check to make sure it actually *is* running.
It seems to be a threading issue. Look at one of the above postings.
> I'd like to hear your results.
> Here's my environment.....
> Linux 7.3
> Tomcat 4 (standalone)
> JDK 1.4 (J2SDK)
> MapServer version 3.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=POSTGIS INPUT=SHAPEFILE
> My data is all in PostGIS
I have nearly the same environment.
Harald
