[mapserver-users] Java Mapscript and Tomcat
Obe, Regina DND\MIS robe.dnd at CI.BOSTON.MA.US
Thu Jun 27 07:19:01 PDT 2002
If you have the call to Mapscript from a jsp page instead of a hand written
servlet does it still cause the same problem?
-----Original Message-----
From: Andreas Hirner [mailto:andreas_hirner at hotmail.com]
Sent: Thursday, June 27, 2002 8:34 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Java Mapscript and Tomcat
Hello,
recently I have started developing servlets using Java Mapscript. I use
Linux as OS and Tomcat as servlet engine. But the development process is
severely hampered by the fact that I have to restart Tomcat every time after
making changes to the servlet. If I only reload the application using the
manager tool, the native Mapscript library is loaded a second time and
causes an error.
I tried to write a class , which loads the library and put it in the
common/lib directory in order avoid multiple loading of the library, but
this does not work.
Does anyone have some hints?
Thanks in advance
Andreas
_________________________________________________________________
Send and receive Hotmail on your mobile device: http://mobile.msn.com
More information about the MapServer-users mailing list
