[mapserver-users] First time users: black output from
mapserver3.6.0using itasca demo dataset
Cedric BERNIER
cedric.bernier at thales-is.com
Fri Jun 28 04:11:28 EDT 2002
same problem , same solution !
thanks all , now I can use mapserver demo.
Tyler Mitchell a écrit :
> Good work Zuki.
> How have you configured mapserver already? Shape files are supported by
> default in mapserver, so don't worry about that. I'm not sure if you can
> get DXF working though. What kind of databases are you wanting to connect
> to?
> Tyler
> | | "Harahap, Zuki" |
> | | <Zuki.Harahap at conoco.com> |
> | | Sent by: |
> | | owner-mapserver-users at lists.|
> | | gis.umn.edu |
> | | 06/26/2002 10:57 PM |
> | To: <mapserver-users at lists.gis.umn.edu> |
> | cc: |
> | Fax to: |
> | Subject: RE: [mapserver-users] First time users: black output from mapserver3.6.0 using itasca demo dataset |
> Thanks everyone. This is really great being part of Open Source
> community!
> The error is due to the images path (in demo_init.html) is not set
> correctly. It runs OK now.
> Now I would like to try to view our files (ESRI shape files, DXF,
> internal databases) via mapserv. I guess I need to recompile mapserv
> again to include support for these types of data. Is there any
> additional manuals/readme available in internet beside the ones in
> http://mapserver.gis.umn.edu/?
> Thanks a lot everyone,
> Zuki
> -----Original Message-----
> From: David Turover [mailto:dturover at student.santarosa.edu]
> Sent: Wednesday, June 26, 2002 10:15 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] First time users: black output from
> On Wed, 26 Jun 2002, Harahap, Zuki wrote:
> > I have installed mapserver 3.6.0 and itasca demo dataset. Installation
> seems OK. But when I looked the result via browser (mozilla, konqueror,
> IE) all I got in MapServer Demo Interface page is a black map with some
> feature on its right side (refresh/query, browse map, query feature, and
> so on). I could click on the map and the mapserv perform an action.
> However, the result is still same, nothing there, only black.
> Are you getting blank images, or is no image showing up at all? If there
> is no image, it could be an issue with the paths in your map file and
> html
> templates. Make sure that they are exactly correct, and check your
> server
> log for 404s looking for images (a clear sign that a file path might be
> in error).
> If you think it is a GIF/PNG issue, you can configure the demo.map file
> to
> make it output PNGs using the "IMAGETYPE png" directive in the beginning
> (global) section of the file. There's a good reference to the mapfile
> commands at http://mapserver.gis.umn.edu/doc36/mapfile-reference.html
> You shouldn't need to recompile, but if nothing else works it may be
> worth a shot. I hope you get it to work without too much trouble.
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020628/8c65d44c/cedric.bernier.vcf
