[mapserver-users] scale with PHP
Daniel Morissette
morissette at dmsolutions.ca
Fri Jun 28 11:14:53 EDT 2002
Guillaume Sueur wrote:
> Are you sure it works for the full extent scale ? I had to write a little
> function to get the scale because at full extent of the map, thereturned
> scale by mapscript was -1. It was Ok for other extents. Strange no ?
Manuel Marichal Pérez wrote:
> I have installed Mapserver 3.6.0 and 3.6.1. In both of them, the "scale"
> member of a MapObj object in PHP/MapScript is always -1 :(
Maybe I should have mentioned that the scale is not computed by
MapServer and MapScript until you call one of $map->draw(),
$map->prepareImage(), $map->prepareQuery() or $map->setExtent().
So an easy way to force calculation of the scale at full extent is to do
this:
$map = ms_newMapObj(...);
$map->setExtent($map->extent->minx, $map->extent->miny,
$map->extent->maxx, $map->extent->maxy);
echo "Map Scale is ".$map->scale;
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
