[mapserver-users] Mapplet
Puneet Kishor
pkishor at GeoAnalytics.com
Thu May 2 12:46:19 EDT 2002
cc-ing to mapserver.
after a cursory check... mapplet _does not_ work on IE 5.1 on MacOS X. Don't
know if it is a java implementation constraint (probably not) or a browser
implementation constraint (probably).
additionally, keep in my mapplet works only with gifs. I have now managed to
create a version of mapplet (actually my local java wiz colleague has for
me) that works with pngs as well. I will be packaging it nicely with docs,
et al, and then we can put it where others can get it.
will try with various other browsers (mozilla, chimera, icab, omniweb, etc.)
and report back.
thanks.
> -----Original Message-----
> From: TCHaddad [mailto:TCHaddad at cshore.com]
> Sent: Wednesday, May 01, 2002 3:37 PM
> To: btolka at gtcomputing.com
> Cc: pkishor at GeoAnalytics.com
> Subject: Re: [mapserver-users] Mapplet
> Bryan,
> I have the same probelm with mapplet vs. Netscape 6.2 (PC).
> The entire page loads, but stalls with message "loading
> applet". I haven't yet woorked to find a solution.
> Every thing works fine for me in Netscape 4.5, 4.7, IE 5.0,
> 5.5 (PC Browsers) and the few unix Netscape browsers I've
> checked, so maybe if you are haveing IE only problems it is a
> paths thing? ...
> Don't think I've had any luck with any Mac browser 9.x or
> below. There is a missing Javascript to Java applet connector
> on those clients if I understand correctly. I'd be interested
> if one of the OS X folks (Puneet?) can confirm that this is
> no longer the case -- say with access to a site like Steve's
> Landview App. (do the maps appear?):
> http://maps.dnr.state.mn.us/landview/
> good luck,
> TH
> ---------- Original Message ----------------------------------
> From: Bryan Tolka <btolka at gtcomputing.com>
> Reply-To: btolka at gtcomputing.com
> Date: Wed, 01 May 2002 14:00:05 -0400
> >Whenever I implemented the mapplet function into my map, the browser
> >always seems to be transferring data, even though everything
> has loaded
> >properly. I am using Netscape 6.2.
> >Any ideas areappreciated.
> >Bryan Tolka
