[mapserver-users] Thousands of layers?
Ed McNierney
ed at topozone.com
Thu May 2 15:00:46 EDT 2002
Pushkar -
While MapScript might be a good idea, I don't think it fundamentally changes James' data organization issue. MapServer can have various layers turn on or off at different zoom scales in the standard CGI app - MapScript isn't required to do that. And MapScript won't help poorly-organized data.
MapScript is a great tool that James should get to know, but it's not necessary for this problem.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Pushkar Pradhan [mailto:pushkar at ERC.MsState.Edu]
Sent: Thursday, May 02, 2002 2:31 PM
To: James Jefferson
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Thousands of layers?
Hi James,
I think it would be better if you use php mapscript/ perl mapscript.
This allows you to turn on/off layers as you wish, so you can:
turn the basic levels when viewing the whole country, then as the user
zooms in into a particular region turn on the detailed layers within that
extent (e.g. streets layers).
> Hello everyone,
> I've been using mapserver for about a year now and one of the problems I've
> struggled with is making a detailed map of the United States - down to the
> street level.
> I have Shapefiles generated from the 1997 TIGER, broken down by county. I've
> noticed in the mapserver documentation that there is a limit of 50 layers per
> mapfile (incidentally, the define in map.h is set to 100). There are a few
> thousand counties in the US, and consquently I think I need a approximately
> 20,000 shapefiles to represent the different layers for each county.
> If I recompile mapserver with MS_MAXLAYERS set higher, how will that affect
> performance? Looking at source it appears that the MS_MAXLAYERS is just used
> to allocate memory for each layer. How does mapserver decide what maps to
> load? I'm assuming it uses the bounding boxes associated with each shapefile
> to determine what file to load? If so, are those read each time mapserver is
> invoxed, or can it have a index file?
> Is anybody else using mapserver for this scale? Advice? Am I on the right
> track at all?
> Thanks,
> -James Jefferson
> Winona, Minnesota
-Pushkar S. Pradhan
