[mapserver-users] Possible to let the user measure distances and
areas?
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 3 07:50:44 EDT 2002
Peter,
I don't think the current Rosa or mapplet applets support this
functionality, but if any of our Java programmers (hint, hint, wink,
nudge) where inclined to add it that would be cool functionality to
have. You would have to extend the applet interface to include some
knowledge about the projection to get accurate computations. At smaller
scales you can probably make some assumptions that make the calculations
simplier by assuming that the points are on a flat plain and not on the
curvature of the earth.
-Steve W.
Peter wrote:
> Hi listers!
> Is it possible to get the distances and areas with mapserver-projects?
> The user should click two times on the map and get the length in meters...
> We have the mapimage within an applet...
> Thanks
> Peter
