[mapserver-users] map layer's sequence
    Joe Bussell
    joe at otsys.com
    Mon May  6 14:23:18 PDT 2002
If you are strictly reliing on the mapfile to define the sequence it
will paint in order of appearance in that file.  If you are iterating
over your layers with a real CGI then you control it explicitly.
Joe Bussell
On Time Systems
On Mon, May 06, 2002 at 12:05:17PM -0700, jason wrote:
> Hi All,
> I am using the MapServer 3.5.1 on Win2000 as WMS server. I config the mapfile to use mapinfo .TAB data via OGR. I found there is no definition in the mapfile for map layer's sequence, and the layer sequence is out of control when rendering the map image. Does anyone have similar problem or know how to get it work?
> Thanks for any input,
> Jason
More information about the MapServer-users
