[mapserver-users] Projection Woes - How to do it (i.e. i really need some help)
Ed McNierney
ed at topozone.com
Thu May 9 13:20:45 EDT 2002
Chip -
The first thing to do is correct the spelling of "ellps" in the line "elips=clrk66".
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Hankley, Chip [mailto:Chip.Hankley at GASAI.Com]
Sent: Thursday, May 09, 2002 12:54 PM
To: MapServer List (E-mail)
Subject: [mapserver-users] Projection Woes - How to do it (i.e. i really
need some help)
Fiddling with projection-on-the-fly today. Working w/ the 3.5 CGI versions
of MapServer, on Win2K, with IIS. When I try to load a mapfile with a
projection specified, I get the following error (map file below):
msProcessProjection(): Projection library error. major axis or radius = 0 or
not given
I'm totally confused by what's in (or not in) the documentation.
1) Do I need to have some local file (like a library) defining projections
somewhere? Where does it go? Do I need to do something different if using
MapScript?
2) What extent do I define in my header: the extent of the map projection,
or the extent of my layer.
3) Why am I getting this error?
TIA!
Chip
NAME library
EXTENT 280482.067224 206170.386312 778816.444758 746364.850613SIZE 400 400
FONTSET "C:\Inetpub\wwwroot\mapserv\ms_symbols\fonts\fonts.list"
SHAPEPATH "C:\ESRI\ESRIDATA\USA\"
SYMBOLSET "C:\Inetpub\wwwroot\MapSymbols\symbol.sym"
UNITS meters
IMAGECOLOR 255 255 255
# Projection definition
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=15"
"north"
"no_defs"
END
WEB
TEMPLATE default.html
IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
IMAGEURL "/tmp/"
END
SCALEBAR
STATUS ON
INTERVALS 2
SIZE 125 2
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
OUTLINECOLOR 0 0 0
UNITS feet
LABEL
COLOR 0 0 0
SIZE small
END
END
LAYER
NAME Counties
TYPE Polygon
STATUS on
PROJECTION
"proj=latlong"
"elips=clrk66"
END
DATA "Counties"
CLASS
Name 'Ctyppoly.shp'
OUTLINECOLOR 0 0 0
END # CLASS
END # LAYER
END
