[mapserver-users] XML mapfile?
    Andrew Hallam
    ahallam at digitalearth.com.au
    Wed May 22 16:22:20 PDT 2002
As a starting point a small app/library could be created that converts an
XML map file to the current map file format. It could use an XML schema to
help validate the content before it is written to disk in native MapServer
format.
Benefits:
1. Allows those who want to work in XML to do so.
2. Generates pre-validated map file (maybe).
3. MapServer tool builders can add nice GUIs.
4. External applications can generate map files.
5. It has no impact on the current MapServer development path and schedule.
6. Easy-ish for someone outside the core developer group to do if they have
the time.
I'll volunteer for a Java library if you can wait until July/August.
Andrew Hallam
More information about the MapServer-users
