[mapserver-users] Can't create Mapsewrver's log file on Linux
Hisaji ONO
hi-ono at mn.xdsl.ne.jp
Thu May 23 10:09:09 EDT 2002
Thank you very much for your advice.
I could write log files.
> Hasaji,
> try
> LOG /var/www/temp/mapserver.log
> i.e. without quotes and the .log file permissions and paths must correct.
> Ma
> > This is my first question in this mailing list.
> > Now I've tried to use mapserver 3.6 with PostGIS 0.7.1 and Apache on
Red
> > Hat Linux 7.2.
> > I've created following map file.
> > NAME EX1
> > EXTENT -159.6 28.77 -71.4667 70.5
> > SIZE 400 300
> > SHAPEPATH "../data"
> > WEB
> > LOG "/var/www/temp/mapserver.log"
> > END
> > LAYER
> > NAME "mines"
> > DATA abnminx020
> > STATUS DEFAULT
> > TYPE POINT
> > CLASS
> > COLOR 120 120 220
> > OUTLINECOLOR 100 10 0
> > END
> > END
> > END
> > Using this Map file, Map images were displayed. However MapServer
couldn't
> > create log file.
> > This "temp" directory's permission was "u+x".
