[mapserver-users] aea projection support?
Daniel Morissette
morissette at dmsolutions.ca
Thu May 23 10:25:09 EDT 2002
In order for reprojection to happen in MapServer, you need to specify
both input and output projections in your mapfile. i.e. you need to
specify the output projection at the top-level in your mapfile, and you
also need to specify the input projection for each layer.
Something to check anyway...
Daniel
allan panitch wrote:
> Hello all,
> I am successfully producing maps of America. But I can seem to get the
> maps to "squish" together to look like a mercator projection.
> America looks elongated as opposed to the way we see it on a globe/map
> like mercator or aea.
> Basically, no matter what I change the projections don't affect the
> output.
> I even tried the pre-built binaries to make sure we didn't leave anything
> out.
> Here is info from my .map file.
> PROJECTION
> "proj=merc"
> # "ellps=GRS80"
> "ellps=clrk66"
> "zone=15"
> "north"
> # "proj=aea"
> # "ellps=clrk66"
> # "lon_0=180"
> "lat_0=180"
> "lat_1=80"
> "lat_2=80"
> # "x_0=10000"
> # "y_0=10000"
> END
