[mapserver-users] Upgrade problems from php3.x to php 4.1.2
Bart van Heijningen
bart at atsence.nl
Tue May 28 10:01:16 EDT 2002
Hi all,
I upgraded php from php 3.x to php 4.1.2
RH 7.0
php 4.1.2
Mapserver 3.5
GD 1.2
I DID compile with; --with-gd=../gd-1.2 and also when issued a phpinfo(), it
listst in the GD section:
(php compilation sring: './configure' '--with-mysql=/usr/local/mysql'
'--with-dbase' '--with-gd=../mapserver/gd-1.2'
'--with-apxs=/usr/local/apache/bin/apxs'
'--with-config-file-path=/usr/local/appache/conf' '--with-system-regex'
'--with-ftp' '--with-module=so'
gd
GD Support enabled
GD Version 1.2
GIF Read Support enabled
GIF Create Support enabled
When initializing one of my mapserver projects I get (the well known) error:
loadSymbol(): GD library error
None of my projects will run anymore.
My conclusion is that PHP 4.1.2 somehow does not use the right GD.
Any help would be greatly welcomed.
Thanks,
Bart
