[mapserver-users] TrueType Font error.
    randy james
    rjames57 at yahoo.com
    Tue May 28 11:56:26 PDT 2002
Hi
I have the same problem its because gd is not built
with truetype support. I am using gd-1.8.4, when I try
and build it with truetype support i keep getting the
error. "else not in conditional statement". (And thats
after I modified the include paths in the source, they
are not setup for my system; mandrake 7.1)
I can see where the else statement needs work, but i
do not have a clue how to fix it. Here is the problem
i found
gcc -I. -I/usr/local/include/freetype2
-I/usr/include/X11 -I/usr/X11R6/include/X
11 -I/usr/local/include  -O -DHAVE_LIBXPM
-DHAVE_LIBPNG -DHAVE_LIBJPEG -DHAVE_LI
BFREETYPE   -c -o gdttf.o gdttf.c
gdttf.c:20: `#else' not within a conditional
make: *** [gdttf.o] Error 1
from gdttf.c
hope someone will be able to fix the problem. I think
i will try gd version 2.xx
randy
ifndef HAVE_LIBTTF
char * gdImageStringTTF(gdImage *im, int *brect, int
fg, char *fontname,
                double ptsize, double angle, int x,
int y, char *string)
	return "libgd was not built with TrueType font
support\n";
#else
--- gabriel <gabriel at ciasc.gov.br> wrote:
> He all.
> We got this message using MapServer 3.5,
> msGetLabelSize(): TrueType Font error. libgd was not
> built with TrueType
> font support
> The MapServer was running under this configuration:
> MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF
> INPUT=EPPL7 INPUT=JPEG INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> and we download it from
> http://mapserver.gis.umn.edu/dist/ms_3.5.tar.gz
> We try to compile, with new specifications. Until
> the moment without
> success.
> Somebody could supply the MapServer 3.5 with
> TrueType Font available ?
> Thanks.
> Gabriel
> Florianópolis - SC - Brasil
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
More information about the MapServer-users
