[mapserver-users] question on CLASSITEM
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 29 18:04:21 EDT 2002
Puneet,
I think that your problem is that you are comparing based on a regular
expression match because you are uing "/$expr/" which is really asking
if $expr is in the the string so /a/ would match "bbbabbb" AND following
that logic // a null pattern will match any string. If you want to match
"" eq "a" to fail, then don't use a regular expression.
-Steve
Puneet Kishor wrote:
> mapfile (only relevant lines shown) --
> LAYER
> NAME "layer_highlight"
> STATUS off
> CLASSITEM "blah"
> CLASS
> ...classdef...
> END
> TEMPLATE "foo"
> END
> mapscript (only relevant lines shown) given $expr for "blah" --
> $layerObj = $mapObj->getlayerbyname("layer_highlight");
> $classObj = $layerObj->getClass(0);
> $classObj->setexpression("/$expr/");
> $layerObj->set("status", 1);
> this turns on "layer_highlight" and highlights the features that match
> CLASSITEM "blah" to "$expr".
> The problem is thus -- if $expr exists then features are correctly matched
> in the layer. However, if $expr == "", then all the features end up getting
> matched... what I want is that if $expr == "" then the layer should turn on,
> however, no feature should show up since no feature is matched.
> Any ideas?
> pk/
