[mapserver-users] New User
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 29 21:34:51 EDT 2002
Simon,
Mapserver is not a Windows GUI application. While it can be run as a
back-end to other applications or via one of the Mapscript languages to
generate map images, its primary design is to function as a CGI
application for a webserver. You can set it up to run with Personal Web
Server on your PC so it can run on a single standalone PC.
-Steve
Simon Kirkness wrote:
> Hi All,
> Am I able to run the MapServer application and Demo on a PC independant
> of a web server?
> Simon Kirkness
> NSW Fisheries
> Project Officer
> Threatened Species
> Port Stephens Fisheries Centre
> Ph: (02) 4916 3810
> Fax: (02) 4916 3880
> Email: kirkness at fisheries.nsw.gov.au
> Note: This message is intended for the addressee named and may contain
> confidential information. If you are not the intended recipient,
> please
> delete it and notify the sender. Views expressed in this message are
> those
> of the individual sender, and are not necessarily the views of NSW
> Fisheries.
> InterScan_Disclaimer.txt Type: Plain Text (text/plain)
> Encoding: 7bit
