[mapserver-users] Font Error:msGetLabelSize()
Ivan Paoluzzi
tesimap at hotmail.com
Wed Oct 2 10:30:24 EDT 2002
I have tried to insert the paths absolut but I have same error
(msGetLabelSize()....).
Now this is my font file:
arial C:/windows/fonts/arial.ttf
timesbd C:/windows/fonts/timesbd.ttf
I have also tried with backslash (I know that it isn't correctly) and I
haven't solved my problem.
Other idea?
Ivan
>From: woodbri at swoodbridge.com
>Reply-To: woodbri at swoodbridge.com
>To: "Ivan Paoluzzi" <tesimap at hotmail.com>,
>mapserver-users at lists.gis.umn.edu
>Subject: Re: [mapserver-users] Font Error:msGetLabelSize()
>Date: Tue, 1 Oct 2002 13:49:36 -0400
>Try making the paths absolute in the fonts.txt like
>arial /path/to/arial.ttf
>-Steve
>On 1 Oct 2002 at 19:24, Ivan Paoluzzi wrote:
> > Hi all,
> > I have compiled mapserver 3.5 on Win XP with Freetype 2 but when I
> > tested my project I have this error:
> > msGetLabelSize(): TrueType Font error. Could not find/open font
> > Before, I used your mapserver precompiled and my project worked
> > correctly with truetype font.
> > This is my fonts file (fonts.txt):
> > arial arial.ttf
> > timesbd timesbd.ttf
> > In FONTSET I have setted the correct path:
> > FONTSET "data/fonts.txt"
> > Because I have copied fonts in this directory of my project.
> > And this is an example of label in my layer:
> > LABEL
> > COLOR 0 0 0
> > FONT arial
> > TYPE TRUETYPE
> > SIZE 8
> > ANTIALIAS TRUE
> > POSITION AUTO
> > ANGLE AUTO
> > MINFEATURESIZE 40
> > MINDISTANCE 100
> > PARTIALS FALSE
> > BUFFER 3
> > END #LABEL
> > Are there some errors?
> > Any helps is appreciated.
> > Ivan
_________________________________________________________________
Specisci e ricevi le tue email Hotmail dal tuo cellulare con:
http://mobile.msn.it
