[mapserver-users] line layer does not appear
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Oct 3 12:21:12 EDT 2002
Hi Toni,
> the streets layer doesn't appear even when the query option
> (in the html
> form) es disabled.
> That's why I am confused.
this is different from what you said the last time. The last time you
said...
> > >>> I have a problem with a line layer.
> > >>> This is my .map file for the layer called carrers.
> > >>> The thing is that if I put # in front of FILTERITEM and
> > >>> FILTER the layer
> > >>> appears.
which implied that the layer appeared when the FILTERs were turned off.
In any case, start troubleshooting step by step. Forget about the
filters.... comment them out.... just the plain old line layer.
Does the layer appear? If not, check your path settings. Assuming other
layers appear, use that as a guide to make sure all your path settings are
correct.
If the layer appears, check to see if you are FILTERing against the correct
attribute, and using values that exist. Watch for capitalization, spaces,
etc.
pk/
> ----- Original Message -----
> From: "Puneet Kishor" <pkishor at geoanalytics.com>
> To: "Toni Hernández" <toni at giscampus.udg.es>
> Cc: "Mapserver" <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, October 03, 2002 3:06 PM
> Subject: Re: [mapserver-users] line layer does not appear
> > On Thursday, October 3, 2002, at 01:28 AM, Toni Hernández wrote:
> > > Hi,
> > > Thanks for the reply.
> > > Is that mean that I can not show a layer and allow the
> user to make a
> > > query
> > > filter (in some other window) at the same time?
> > no, not at all... its just that it seems your current filter is not
> > matching anything. If you ask the program to match against
> some item,
> > and nothing matches, then nothing will show.
> > make sure you've got the item name, values, etc., right.
> > pk/
> > ps. please reply to the entire list, so others may also be able to
> > help/benefit. thanks.
> > > To: "'Toni Hernández'" <toni at giscampus.udg.es>;
> > > Sent: Wednesday, October 02, 2002 7:48 PM
> > > Subject: RE: [mapserver-users] line layer does not appear
> > >>> -----Original Message-----
> > >>> From: Toni Hernández [mailto:toni at giscampus.udg.es]
> > >>> Sent: Wednesday, October 02, 2002 12:00 PM
> > >>> To: mapserver-users at lists.gis.umn.edu
> > >>> Subject: [mapserver-users] line layer does not appear
> > >>> hi everybody,
> > >>> FILTER the layer
> > >>> appears.
> > >> are you trying to say that ordinarily (that is, if you
> *don't* have a
> > >> # in
> > >> front of FILTERITEM and FILTER), the line layer
> "carrers" does not
> > >> show?
> > >> When you don't have the # in front of the FILTER*
> keywords, there is
> > >> filtering going on. On those features from "carrers" will show up
> > >> where
> > > the
> > >> item "nom" matches whatever the value of %name% happens
> to be. Perhaps
> > > there
> > >> is no match, hence nothing shows up. When you comment
> the filters out
> > >> (by
> > >> putting # in front of them), the layer shows up because it is not
> > >> being
> > > put
> > >> through the filter.
> > >> Does this help?
> > >> pk/
> > >>> Anyone know why???
> > >>> LAYER
> > >>> NAME carrers
> > >>> TYPE LINE
> > >>> DATA carrers
> > >>> STATUS on
> > >>> FILTERITEM "Nom"
> > >>> FILTER "%name%"
> > >>> CLASS
> > >>> NAME "l_carrers"
> > >>> COLOR 0 255 0
> > >>> TEMPLATE "carrers.html"
> > >>> END
> > >>> LABELITEM Nom
> > >>> HEADER "cap_carrers.html"
> > >>> FOOTER "peu_carrers.html"
> > >>> END
> > >>> Thanks a lot
