[mapserver-users] DATUM CONVERSIONS
Jaime Mejía
jomejia at main-task.com
Fri Oct 4 20:35:59 EDT 2002
hi list,
I've got a base map in XY coordinates with datum bogota.
In the map file, I've got the following projection definition:
# Start of map file
NAME BOGOTA
STATUS ON
SIZE 600 600
SYMBOLSET "/usr/local/apache/htdocs/bog/symbols/symbol.sym"
EXTENT 250000 20000 2110000 1880000
UNITS METERS
SHAPEPATH "/usr/local/apache/htdocs/bog/data/"
IMAGECOLOR 240 240 240
FONTSET "/usr/local/apache/htdocs/bog/fonts/fonts.txt"
# View Projection definition
PROJECTION
"proj=tmerc"
"ellps=intl"
"k=0.9996"
"x_0=1000000"
"y_0=1000000"
"lon_0=74d4.8550002'w"
"lat_0=4d35.9428332'n"
END
And I want to display in the map a collection of points taken with a GPS
and datum WGS84.
How do I define the projection in the layer?
If I take the points with GPS datum BOGOTA it appears where they should,
but with WGS84 it
appears +/- 500 mts displaced to the south-east
I've got the projection in the layer defined this way:
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
The problem is that there is about 500.000 points, so it is impossible
to take them again with
datum BOGOTA.
I used a Garmin GPS
What should I do?
Thanks in advance,
Cordial Saludo,
MAIN TASK
Jaime Mejía Molina
www.main-task.com
Teléfono 2184608
DG 85 # 28-39
Bogotá D. C.
