[mapserver-users] Java MapScript Win32 DLL
Andrew Collins
andrewrcollins at yahoo.com
Sun Oct 6 08:13:37 EDT 2002
Steps taken:
1. Compiled MapServer with gcc using MinGW and MSYS.
2. Generated MapScript C and Java code with swig.
3. Produced dll with dlltool and gcc using MinGW and MSYS.
I have had absolutely no luck using the dll. This is the
first time that I've used MinGW, MSYS, dlltool, gcc and
swig to produce a dll. I'm certain that I have missed
some fundamental steps somewhere. Here is a listing of
the files I've used, the commands I've executed and the
changes to the 3.6.1 distribution that I've made to
produce the "mapscript_java.dll" file:
A batch file to download all the necessary files, makes
use of "curl", but "wget" would probably work, too...
@echo off
echo mapserver-3.6.1.tar.gz
curl "http://mapserver.gis.umn.edu/dist/mapserver-3.6.1.tar.gz" --output
"mapserver-3.6.1.tar.gz"
echo swigwin-1.3.15.zip
curl "http://telia.dl.sourceforge.net/sourceforge/swig/swigwin-1.3.15.zip"
--output "swigwin-1.3.15.zip"
echo MinGW-2.0.0-3.exe
curl "http://telia.dl.sourceforge.net/sourceforge/mingw/MinGW-2.0.0-3.exe"
--output "MinGW-2.0.0-3.exe"
echo MSYS-1.0.8-2002.09.07-1.exe
curl
"http://telia.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.8-2002.09.07-1.exe"
--output "MSYS-1.0.8-2002.09.07-1.exe"
echo gdlib-1.8.4-lib.zip
curl "http://telia.dl.sourceforge.net/sourceforge/gnuwin32/gdlib-1.8.4-lib.zip"
--output "gdlib-1.8.4-lib.zip"
echo freetype-2.1.2-1-lib.zip
curl
"http://telia.dl.sourceforge.net/sourceforge/gnuwin32/freetype-2.1.2-1-lib.zip"
--output "freetype-2.1.2-1-lib.zip"
echo libjpeg-6b-lib.zip
curl "http://telia.dl.sourceforge.net/sourceforge/gnuwin32/libjpeg-6b-lib.zip"
--output "libjpeg-6b-lib.zip"
echo libpng-1.2.4-1-lib.zip
curl
"http://telia.dl.sourceforge.net/sourceforge/gnuwin32/libpng-1.2.4-1-lib.zip"
--output "libpng-1.2.4-1-lib.zip"
echo xpm-3.4k-1-lib.zip
curl "http://telia.dl.sourceforge.net/sourceforge/gnuwin32/xpm-3.4k-1-lib.zip"
--output "xpm-3.4k-1-lib.zip"
echo zlib-1.1.4-lib.zip
curl "http://telia.dl.sourceforge.net/sourceforge/gnuwin32/zlib-1.1.4-lib.zip"
--output "zlib-1.1.4-lib.zip"
echo regex-0.12-lib.zip
curl "http://telia.dl.sourceforge.net/sourceforge/gnuwin32/regex-0.12-lib.zip"
--output "regex-0.12-lib.zip"
pause
1. Install MinGW
E:\win32app\MinGW
2. Install MSYS
E:\win32app\MinGW\1.0
3. Unzip Swig
E:\win32app\SWIG-1.3.15
4. Unzip MapServer
E:\win32app\MinGW\1.0\bin\%USERPROFILE%\mapserver-3.6.1
5. Unzip required libraries
gdlib-1.8.4-lib.zip
libjpeg-6b-lib.zip
xpm-3.4k-1-lib.zip
zlib-1.1.4-lib.zip
regex-0.12-lib.zip
E:\win32app\MinGW\1.0\bin\%USERPROFILE%\mapserver-3.6.1\include
E:\win32app\MinGW\1.0\bin\%USERPROFILE%\mapserver-3.6.1\lib
E:\win32app\MinGW\1.0\bin\%USERPROFILE%\mapserver-3.6.1\manifest
6. Run MSYS
$ cd
$ cd mapserver-3.6.1
$ mv lib/libgd.dll.a lib/libgd_dll.a
$ mv mapogr.cpp mapogr.c
$ vi configure
Change two lines:
GD_CHECKLIB=c
to:
GD_CHECKLIB=gd
$ ./configure --with-jpeg=. --with-gd=. --with-freetype=. --with-zlib=.
--with-png=. --without-pdf --without-tiff --without-eppl --without-wms
--without-php
$ vi Makefile
Change line:
mapogr.o: mapogr.cpp
$(CXX) -c $(CFLAGS) mapogr.cpp -o mapogr.o
to:
#mapogr.o: mapogr.cpp
# $(CC) -c $(CFLAGS) $< -o $@
$ make lib
$ cd mapscript
$ cd java
$ cp ../mapscript.i .
Use the following "Makefile"
# SWIG Stuff
SWIG=/e/win32app/SWIG-1.3.15/swig
# Java Stuff
JAVAC=/e/win32app/j2sdk1.4.1/bin/javac
JAR=/e/win32app/j2sdk1.4.1/bin/jar
JAVA_INCLUDE=-I/e/win32app/j2sdk1.4.1/include
-I/e/win32app/j2sdk1.4.1/include/win32
CC=gcc
# Set these to the values appropriate for your MapServer build- cut & paste
from ../../perlvars
CCFLAGS=-DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_TTF
-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DGD_HAS_GDIMAGEGIFPTR
LDFLAGS=-Wl,--dll -nostartfiles -L../.. -lmap -L../../lib -lgd -lgd_dll -lpng
-lpng12_dll -lz -lz_dll -ljpeg -ljpeg_dll -lfreetype -lfreetype_dll -lttf
-ltty_dll -lregex -lregex_dll
# --- You shouldn't have to edit anything else. ---
all: interface mapscript_dll mapscript_java mapscript_jar
interface: mapscript.i
$(SWIG) -I../.. -java -shadow -package edu.umn.gis.mapscript mapscript.i
mapscript_dll: mapscript_wrap.c
$(CC) -c $(CCFLAGS) $(JAVA_INCLUDE) -I../../ -I../../include/ mapscript_wrap.c
dlltool --dllname mapscript_java.dll --output-exp mapscript_java.o
--output-lib mapscript_java.lib --output-def mapscript_java.def
mapscript_wrap.o
$(CC) mapscript_wrap.o mapscript_java.o -o mapscript_java.dll $(LDFLAGS)
mapscript_java::
$(JAVAC) -d . *.java
mapscript_jar::
$(JAR) cf mapscript.jar edu
clean:
rm -rf *.c *.o *.def *.lib *.dll edu *.java *.jar
$ make
The resulting "mapscript_java.dll" doesn't work.
Andrew Collins - andrewrcollins at yahoo.com
http://profiles.yahoo.com/andrewrcollins/
__________________________________________________
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
