[mapserver-users] Antialiased Lines in mapserver?
woodbri at swoodbridge.com
Mon Oct 7 23:14:34 EDT 2002
It would also be very easy to modify the GD 1.x function calls to
make them unique. Then it would be easy to have both. It also might
make some sense to load the IMAGETYPE <type> as a <type>.so then you
don't have to worry about library name space collisions.
-Steve
On 7 Oct 2002 at 19:58, Joe Bussell wrote:
> It may be the case that there are enough of us who need a slim,
> light-weight GD that is capable of scaling its footprint and selection
> of algorithm based on the users needs. This may require a seperate
> development branch specific to our common needs. Steve's suggestion
> regarding updating GD to perform antialiasing adds weight to this
> choice.
> What is the level of cooperation between the developers of GD and the
> open GIS community? Are the folks at Boutell.Com responsive to
> development feedback? Has anyone considered basing a new development
> effort to create a light-weight, thread-safe image redering library
> based on the GD core which is specifically targeted to web apps?
> In any case I am for sacrificing alternative rendering formats and
> wiz-bang glitz for raw speed. I need to generate relatively useful
> results for a large data set fast. Speed is everything. I would like
> my preprocess which creates a set of rasters of the static data to
> make use of the best rendering possible. In that case speed is not as
> critical. For live content the situation is vastly different.
> Cordially,
> Joe Bussell
> On Time Systems
> www.TrafficDodger.com
> On Mon, Oct 07, 2002 at 07:44:15PM -0400, woodbri at swoodbridge.com
> wrote: > On 7 Oct 2002 at 14:59, Steve Lime wrote: > > > I'm sorta
> hoping that GD 2.0 will offer anti-aliasing. It's not that > > hard
> and there are numerous algorithms out there. Way back I actually > >
> looked into using ImageMagick instead of GD. However, the author of IM
> > > warned that in tests GD was approximately 6 times faster than IM.
> > > That's a hefty price to pay for smooth lines. > > I think that
> this should be evaluated again in light of the fact that > GD 2.0 will
> be using deeper image depth that will impact performance. > > Which
> raises another question in my mind. > > Would it make sense to or is
> it planned that the output routines will > be installable or
> selectable at runtime (maybe via the map file) so > for applications
> that need the performance but can live with GD 1.x > image quality can
> get it, while other apps can get the features they > need? > >
> Shouldn't it be possible to have output drivers for GD 1.x, GD 2.x, >
> ImageMagick, Postscript, Flash, etc. Assuming that someone implements
> > each of them. > > -Steve W. > > > In my opinion, it might be easier
> to update GD to do antialiasing than > > to use IM. The new arch is
> not well documented yet since a production > > version has not even
> been released yet. Basically it would consist of > > functions to draw
> shapeObj's a points, lines and polygons given > > MapServers
> symbolization scheme. > > > > Steve > > > > Stephen Lime > > Data &
> Applications Manager > > > > Minnesota DNR > > 500 Lafayette Road > >
> St. Paul, MN 55155 > > 651-297-2937 > > > > >>> David Monterroso
> Cabello <pyro-x at ixine.com> 10/03/02 09:52AM >>> > > Daniel Morissette
> wrote: > > > > >David Monterroso Cabello wrote: > > > > > > > > >>
> And finally, a question for developers, would it be possible to > >
> >>switch to ImageMagick for vector rendering?, that library render > >
> fine > > >>antialiased lines =), althought i dunno if it support
> everything > > >>mapserver needs. > > >> > > >> > > >> > > > > > >I
> had a quick look at the ImageMagick website and saw that they > >
> support > > >a good set of vector rendering functions, so adding
> ImageMagick as a > > new > > >(optional) output system would be
> possible in the new architecture > > >developed in version 3.7. As
> usual, we just need someone with time > > to > > >do this, or money to
> fund this work. > > > > > > > > > > Yes, i thought the same when
> i saw IM web, i dunno if it is very > > difficult but if finally there
> is no other way to do antialiasing and > > > > you think is posible i
> would like to try to implement it. Do you know > > > > about any doc
> or something i can read to understand the new output > >
> architecture?. > > > > Many thx > > > > > > > > >
