[mapserver-users] Announcing 3.6.3
Joe Bussell
joe at otsys.com
Tue Oct 8 18:59:19 EDT 2002
What are the dependencies for PERL mapscript? Seems this all worked
before...
.../mapserver-3.6.3/mapscript/perl$ make
cp mapscript.pm blib/lib/mapscript.pm
cc -c -I/mnt/data/td/mapserver-3.6.3 -I/usr/include -I/home/joe/gdal/port -I/home/joe/gdal/core -I/home/joe/gdal/ogr -I/home/joe/gdal/ogr/ogrsf_frmts -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O3 -DVERSION=\"\" -DXS_VERSION=\"\" -fPIC "-I/usr/lib/perl/5.8.0/CORE" -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL mapscript_wrap.c
mapscript_wrap.c: In function `_swig_create_magic':
mapscript_wrap.c:416: warning: assignment from incompatible pointer type
mapscript_wrap.c:417: warning: assignment from incompatible pointer type
mapscript_wrap.c: At top level:
mapscript_wrap.c:16349: conflicting types for `boot_mapscript'
mapscript_wrap.c:431: previous declaration of `boot_mapscript'
make: *** [mapscript_wrap.o] Error 1
On Tue, Oct 08, 2002 at 03:00:14PM -0500, Steve Lime wrote:
> Greetings folks: The MapServer development team is pleased to announce
> the release of version 3.6.3. It contains a a number of bug fixes and if
> possible users are encouraged to upgrade now. The new version is
> available at the usual place on the MapServer website.
> Pre-compiled binary versions are available for download at:
> http://www2.dmsolutions.ca/mapserv/dl/mapserver-3.6.3-win32-php4.2.2-libwww.zip
> http://www2.dmsolutions.ca/mapserv/dl/mapserver-3.6.3-win32-php4.2.3-libwww.zip
> Enjoy- Steve
> A summary of changes from HISTORY.TXT:
> Version 3.6.3 (2002-10-07)
> - Fixed problem with numeric labels with OGR's STYLEITEM AUTO (bug
> 185)
> - PHP MapScript: fixed set() method on all object types for parameters
> of type float and string. The param value was not forced to the
> right
> type and this could lead to unexpected values being set or crashes.
> - Fixed bug 174 - improperly terminated string buffer in
> msWMSException()
> - Fixed problem with 'gcc undef' appearing in the
> mapscript/php3/Makefile
> on FreeBSD. Also added --enable-internal-ld-detect configure switch
> to
> force use of an internal configure macro to detect ld command and
> args
> in case the default doesn't work (this is for mapscript/php3/Makefile
> only)
> - Fixed potential crash with WMS GML query output (missing
> msInitSHape() in
> msGMLWriteQuery())
> - Fixed Windows-specific problem where WMS capabilities were always
> returned
> as 1.0.0 even if 1.1.0 was requested
> Version 3.6.2 (2002-07-08)
> - Added msTokenizeMap() in MapScript (and via 'mapserv -t test.map')
> - Added map->setFontSet()
> - Fixed Windows-specific problem with PHP MapScript ms_newMapObj("")
> called with empty filename.
> - Fixed problem with double 'gcc' appearing in mapscript/php3/Makefile
> on
> some systems.
Cordially,
Joe Bussell
On Time Systems
www.TrafficDodger.com
