[mapserver-users] Announcing 3.6.3
Pericles S. Nacionales
nacional at biosci.cbs.umn.edu
Tue Oct 8 20:31:36 EDT 2002
I've also updated the win32 binaries in the mapserver web site:
http://mapserver.gis.umn.edu/win32binaries.html
As always,there's no support for php on these binaries. You'll have to
get the aforementioned binaries at DM Solutions' if you need the php
support.
-Perry
On Tue, 2002-10-08 at 15:00, Steve Lime wrote:
> Greetings folks: The MapServer development team is pleased to announce
> the release of version 3.6.3. It contains a a number of bug fixes and if
> possible users are encouraged to upgrade now. The new version is
> available at the usual place on the MapServer website.
> Pre-compiled binary versions are available for download at:
> http://www2.dmsolutions.ca/mapserv/dl/mapserver-3.6.3-win32-php4.2.2-libwww.zip
> http://www2.dmsolutions.ca/mapserv/dl/mapserver-3.6.3-win32-php4.2.3-libwww.zip
> Enjoy- Steve
> A summary of changes from HISTORY.TXT:
> Version 3.6.3 (2002-10-07)
> - Fixed problem with numeric labels with OGR's STYLEITEM AUTO (bug
> 185)
> - PHP MapScript: fixed set() method on all object types for parameters
> of type float and string. The param value was not forced to the
> right
> type and this could lead to unexpected values being set or crashes.
> - Fixed bug 174 - improperly terminated string buffer in
> msWMSException()
> - Fixed problem with 'gcc undef' appearing in the
> mapscript/php3/Makefile
> on FreeBSD. Also added --enable-internal-ld-detect configure switch
> to
> force use of an internal configure macro to detect ld command and
> args
> in case the default doesn't work (this is for mapscript/php3/Makefile
> only)
> - Fixed potential crash with WMS GML query output (missing
> msInitSHape() in
> msGMLWriteQuery())
> - Fixed Windows-specific problem where WMS capabilities were always
> returned
> as 1.0.0 even if 1.1.0 was requested
> Version 3.6.2 (2002-07-08)
> - Added msTokenizeMap() in MapScript (and via 'mapserv -t test.map')
> - Added map->setFontSet()
> - Fixed Windows-specific problem with PHP MapScript ms_newMapObj("")
> called with empty filename.
> - Fixed problem with double 'gcc' appearing in mapscript/php3/Makefile
> on
> some systems.
