[mapserver-users] PostGIS performance
Jan Hartmann
jhart at frw.uva.nl
Wed Oct 9 05:44:31 EDT 2002
Alexander Pucher wrote:
> I think the problem is in the use of the EXPRESSION with a PostGIS
> layer. In the documentation I found a line, saying that CLASSITEM is not
> used in a PostGIS layer. One has to use the field name in the EXPRESSION
> tag!!
Where did you read that??? Anyway, it's not true. My test-mapfile (a
small world file with the continents) runs as follows:
LAYER
NAME CONTINENTS
CONNECTIONTYPE POSTGIS
CONNECTION "user=xxx dbname=world password=xxx host=xxx"
DATA "the_geom from (select map.the_geom,map.oid,map.continent, case
when map.continent='Europe' then 1 when map.continent='Africa' then 2
else 3 end as cnt from continents as map) as foo"
TYPE POLYGON
CLASSITEM cnt
CLASS
NAME "Asia: black"
EXPRESSION ('[continent]' = 'Asia')
COLOR 0 0 0
OUTLINECOLOR 0 0 0
END
CLASS
NAME "Europe: red"
EXPRESSION "1"
# EXPRESSION /1/ # OK
# EXPRESSION 1 # Doesn't work
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
CLASS
NAME "Africa: magenta"
EXPRESSION "2"
COLOR 255 0 255
OUTLINECOLOR 0 0 0
END
CLASS
NAME "Rest of the World: yellow"
EXPRESSION ([cnt] = 3)
# EXPRESSION ("[cnt]" = "3") # OK
COLOR 255 255 0
OUTLINECOLOR 0 0 0
END
STATUS DEFAULT
END
To be noted:
1) You can use both an EXPRESSION from a CLASSITEM and a logical EXPRESSION.
2) You can use both an original variable and a computed one, provided
you have named them in the subselect.
3) In literal EXPRESSIONS numeric variables have to be quoted or
constructed as regex.
4) In logical EXPRESSIONS you can use numeric variables as numeric or as
strings.
Cheers,
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
