[mapserver-users] FILTER and FILTERITEM parameters in Map file
KRUSEMARK Matthew G
matthew.g.krusemark at co.multnomah.or.us
Wed Oct 9 17:32:07 EDT 2002
Thanks to many folks for trying to help me out with my FILTER and FILTERITEM
params in my mapfile with 3.6. So I tried to trouble-shoot with the
suggestions folks provided. I am in a windows environment and I'm wondering
if my params with the 3.5 test suite are not working because of that or
because I have errored on syntax, not sure. My map file, html query and
html template files are below if anyone wants to take one more look or test
in their windows environment.
My error message: msQueryByAttributes(): Search returned no results. No
matching record(s) found.
My URL string for 3.3 cgi exe is the following and works just fine (but this
uses the QUERY param in the map file, no FILTERITEM or FILTER params):
http://gisshare/cgi-bin/mapserv33.exe?map=D%3A%5CInetpub%5Cwwwroot%5Cgis
share_web%5Cmapserver_demo36%5Citasca%5Ccase1.map&mode=itemquery&item=cty_na
me&value=Anoka
My URL string for 3.6 cgi exe is the following (same but with qlayer in the
cgi and FILTERITEM and FILTER in map file) but does not work:
http://gisshare/cgi-bin/mapserv.exe?map=D%3A%5CInetpub%5Cwwwroot%5Cgissh
are_web%5Cmapserver_demo36%5Citasca%5Ccase1.map&mode=itemquery&qlayer=county
&item=cty_name&value=Anoka
****** MAPFILE BELOW ***********
MAP
NAME test
SHAPEPATH "D:\Inetpub\wwwroot\gisshare_web\mapserver_demo36\itasca\data"
SIZE 300 300
EXTENT 74000 4775000 798000 5499000
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
NAME county
DATA county
STATUS DEFAULT
TYPE POLYGON
FILTERITEM cty_name
FILTER "%cty_name%"
# FILTER "name != 'Anoka'"
CLASS
COLOR 212 212 212
OUTLINECOLOR 0 0 0
TEMPLATE case1_template.html
END
END
# 3.3 stuff below
#LAYER
# NAME county
# DATA county
# STATUS DEFAULT
# TYPE POLYGON
# QUERY
# TEMPLATE case1_template.html
# END
#END
END
******** HTML with Query below **********
<html>
<head>
<title>ItemQuery Example</title>
</head>
<body bgcolor="#ffffff">
<font size="+1" face="arial,helvetica"><b>Case 1: Simple
ItemQuery</b></font>
<form method="get" action="/cgi-bin/mapserv.exe">
<input type="hidden" name="map"
value="D:\Inetpub\wwwroot\gisshare_web\mapserver_demo36\itasca\case1.map">
<input type="hidden" name="mode" value="itemquery">
<input type="hidden" name="qlayer" value="county">
<input type="hidden" name="item" value="cty_name">
Pick one:
<select name="value" size="1">
<option> Aitkin
<option> Anoka
<option> Becker
</select>
<input type="submit" value="Go!">
</form>
</body>
</html>
********** HTML Template below ************
<html>
<head>
</head>
<font size="+2" face="arial,helvetica"><b>Case 1: Simple
<p>
Dump of attributes from that county:
<p>
<b>Name:</b> [CTY_NAME]<br>
<b>ID Number:</b> [COUN]<br>
<b>Abbreviation Code:</b> [CTY_ABBR]<br>
</body>
</html>
Kind regards,-matthew
