[mapserver-users] Sudden failure to find libttf.so.4.0
Daniel Morissette
morissette at dmsolutions.ca
Thu Oct 10 10:42:02 EDT 2002
I can't explain why this happened (only your system admin could), but it
is very likely that something changed on the server and
/usr/home/gisweb/local/lib/ is no longer part of the runtime library
path of the user running the web server.
On Linux, you could edit /etc/ld.so.conf and add this path, and then run
/sbin/ldconfig to rescan the library path.
You could also use the following in your Apache httpd.conf:
SetEnv LD_LIBRARY_PATH /usr/home/gisweb/local/lib
PassEnv LD_LIBRARY_PATH
(make sure you include any other required path in LD_LIBRARY_PATH as
well)
Daniel
gisweb at lmi.net wrote:
> Mighty List:
> Successful install of mapserver version 3.6.1 on our FreeBSD platform put smiles
> on all faces. Performance and cartographic quality were magnificent. The build
> consisted of the following options:
> > /usr/home/gisweb/www/cgi-bin/mapserv -v
> MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORT
> S=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> Smiles vanished, however, when mapserver suddenly ceased working yesterday. The
> apache error_log reports the following:
> > tail -3 /usr/home/gisweb/www/logs/error_log
> ld.so failed: Can't find shared library "libttf.so.4.0"
> [Wed Oct 9 18:53:58 2002] [error] [client 32.102.91.129] Premature end of scrip
> t headers: /usr/home/gisweb/www/cgi-bin/mapserv
> And yet, gentle reader, the supposedly missing libttf.so.4.0 library remains
> where it has always been, exactly where mapserv expects to find it (as
> illustrated by the output of ldd and confirmed by the output of ls -l).
> > ldd /usr/home/gisweb/www/cgi-bin/mapserv
> /usr/home/gisweb/www/cgi-bin/mapserv:
> -lm.2 => /usr/lib/libm.so.2.0 (0x2007a000)
> -lpng.3 => /usr/local/lib/libpng.so.3.0 (0x20094000)
> -lz.2 => /usr/lib/libz.so.2.0 (0x200ad000)
> -ljpeg.9 => /usr/local/lib/libjpeg.so.9.0 (0x200b9000)
> -lttf.4 => /usr/home/gisweb/local/lib/libttf.so.4.0 (0x200d5000)
> -lpdf.1 => /usr/local/lib/libpdf.so.1.1 (0x200fa000)
> -ltiff.3 => /usr/local/lib/libtiff.so.3.0 (0x20121000)
> -lproj.3 => /usr/local/lib/libproj.so.3.1 (0x2015e000)
> -lc.3 => /usr/lib/libc.so.3.1 (0x2018c000)
> > ls -l /usr/home/gisweb/local/lib
> total 1396
> -rw-r--r-- 2 gisweb wheel 10194 Sep 20 09:04 gd.h
> -rw-r--r-- 2 gisweb wheel 917 Sep 20 09:04 gd_io.h
> -rw-r--r-- 1 gisweb wheel 185736 Sep 20 09:04 libgd.a
> -rw-r--r-- 1 gisweb wheel 436250 Sep 24 13:54 libmap.a
> -rwxr-xr-x 1 gisweb wheel 641 Sep 20 08:33 libttf.la
> -rwxr-xr-x 1 gisweb wheel 757868 Sep 20 08:33 libttf.so.4.0
> Who can explain this unusual twist of fate and restore mapserv to its original
> triumphant glory?
> Don't hesitate, gentle reader; speak up! Let the bells of freedom ring!
> Ever hopefull,
> Jonathan W. Lowe
> www.giswebsite.com
