[mapserver-users] Sudden failure to find libttf.so.4.0
gisweb at lmi.net
gisweb at lmi.net
Thu Oct 10 18:57:02 EDT 2002
List:
Daniel's suggestion to add the SetEnv LD_LIBRARY_PATH /my/local/lib (shown
below) was successful. Mapserv is back in service!
Thanks, Daniel!
Regards,
Jonathan W. Lowe
www.giswebsite.com
Quoting Daniel Morissette <morissette at dmsolutions.ca>:
> I can't explain why this happened (only your system admin could), but it
> is very likely that something changed on the server and
> /usr/home/gisweb/local/lib/ is no longer part of the runtime library
> path of the user running the web server.
> On Linux, you could edit /etc/ld.so.conf and add this path, and then run
> /sbin/ldconfig to rescan the library path.
> You could also use the following in your Apache httpd.conf:
> SetEnv LD_LIBRARY_PATH /usr/home/gisweb/local/lib
> PassEnv LD_LIBRARY_PATH
> (make sure you include any other required path in LD_LIBRARY_PATH as
> well)
> Daniel
> gisweb at lmi.net wrote:
> > Mighty List:
> > Successful install of mapserver version 3.6.1 on our FreeBSD platform put
> smiles
> > on all faces. Performance and cartographic quality were magnificent. The
> build
> > consisted of the following options:
> > > /usr/home/gisweb/www/cgi-bin/mapserv -v
> > MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORT
> > S=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=SHAPEFILE
> > Smiles vanished, however, when mapserver suddenly ceased working yesterday.
> The
> > apache error_log reports the following:
> > > tail -3 /usr/home/gisweb/www/logs/error_log
> > ld.so failed: Can't find shared library "libttf.so.4.0"
> > [Wed Oct 9 18:53:58 2002] [error] [client 32.102.91.129] Premature end of
> scrip
> > t headers: /usr/home/gisweb/www/cgi-bin/mapserv
> > And yet, gentle reader, the supposedly missing libttf.so.4.0 library
> remains
> > where it has always been, exactly where mapserv expects to find it (as
> > illustrated by the output of ldd and confirmed by the output of ls -l).
> > > ldd /usr/home/gisweb/www/cgi-bin/mapserv
> > /usr/home/gisweb/www/cgi-bin/mapserv:
> > -lm.2 => /usr/lib/libm.so.2.0 (0x2007a000)
> > -lpng.3 => /usr/local/lib/libpng.so.3.0 (0x20094000)
> > -lz.2 => /usr/lib/libz.so.2.0 (0x200ad000)
> > -ljpeg.9 => /usr/local/lib/libjpeg.so.9.0 (0x200b9000)
> > -lttf.4 => /usr/home/gisweb/local/lib/libttf.so.4.0 (0x200d5000)
> > -lpdf.1 => /usr/local/lib/libpdf.so.1.1 (0x200fa000)
> > -ltiff.3 => /usr/local/lib/libtiff.so.3.0 (0x20121000)
> > -lproj.3 => /usr/local/lib/libproj.so.3.1 (0x2015e000)
> > -lc.3 => /usr/lib/libc.so.3.1 (0x2018c000)
> > > ls -l /usr/home/gisweb/local/lib
> > total 1396
> > -rw-r--r-- 2 gisweb wheel 10194 Sep 20 09:04 gd.h
> > -rw-r--r-- 2 gisweb wheel 917 Sep 20 09:04 gd_io.h
> > -rw-r--r-- 1 gisweb wheel 185736 Sep 20 09:04 libgd.a
> > -rw-r--r-- 1 gisweb wheel 436250 Sep 24 13:54 libmap.a
> > -rwxr-xr-x 1 gisweb wheel 641 Sep 20 08:33 libttf.la
> > -rwxr-xr-x 1 gisweb wheel 757868 Sep 20 08:33 libttf.so.4.0
> > Who can explain this unusual twist of fate and restore mapserv to its
> original
> > triumphant glory?
> > Don't hesitate, gentle reader; speak up! Let the bells of freedom ring!
> > Ever hopefull,
> > Jonathan W. Lowe
> > www.giswebsite.com
